Vp600 programming cable help
Recce_randy
Is the programming cable for a vp600 available anywhere or is compatible with other models of Ef Johnson programming cables?
kd4efm
EL98 Florida
I ordered off ebay to get one that db9 to side port. Like 15 20$
DeoVindice
P25 Underground
5150 Level
It's a different cable from the 5100 even though they both use the Jedi-type connector. The VP family utilizes USB-LAN rather than serial.
The straight-through USB cable is part number 5970600970; I bought one through our dealer this summer. The VP600 is supposed to go out of support right about now so it might be wise to order one while they're still available.
Recce_randy
Any dealer you recommend?
Recce_randy
Heard that you’re a dealer in fl I’m in fl as well can’t message you on here for some reason but if you can order cables I’d be interested in buying and we’ll as looking into some vp8000s
kd4efm
EL98 Florida
I have a cable on order for another customer, I will advise when it gets to me.
Told there are aprox 300 left, but EOL
