VP8000 FW update
Project25_MASTR
TX-COMU
Texas
Its funny when someone else knows more about a product than the so called factory reps.
I mean...but do they really? Take a look at my signature for example. End users and dealers aren't bound to maintain corporate information standards that employees are held to. For example, someone like @kd4efm may be openly allowed to discuss features, hardware country of origin, and speculate what could be added at a later date where I'm only allowed to say, if you have an issue contact support or if you have a volume need for a feature that is not currently available...let your sales rep know so they can mark it in their regular sales report as a loss or potential loss due the lack of the feature so there is a way for developmental needs to accurately be assessed.
AM909
Radio/computer geek
SoCal
More or less on the topic, does the newest version of Armada fix the issue with 1.36.24 that blocks a lot of fields in trunked systems? We're staying with 1.36.20 until that gets fixed. The state-wide system expects us to be able to edit those fields.
Which fields?
I haven't used Armada on trunking yet. Are there test system keys (at least P25) that will allow me to learn how Armada does things? Not looking to program a radio with it – just work on a codeplug before I have to make it work on a real system.
AF1UD
Which fields?
You can create a codeplug, but it will state at the bottom that you need an AKEY to write.
LTR
Ohio
When EFJ came out with the new software that opened up the fields in trunked systems, a bunch of system owners complained, so they closed it again because of that. There is a way around the blocks if the system owner allows you to make changes, the system owner has to uncheck the "Use Strict System Key Rules" box for the System in the codeplugs and that should open things up again.
kd4efm
EL98 Florida
noted by @LTR
if this is unchecked, you should be able to make the minor adjustments.
E55 is a demo system and key I have, so no, this is not a LEGIT on the air system, it's bogus
unless someone wants to get fancy and use my key, then fair game.
