VTac 36?
joetnymedic
West Haven, CT
Hey Guys :) ,
I'm trying to find the frequency and PL/DPL/Nac for VTac 36. I guess it's a pretty new freq. By chace does anyone know what it is? Also, how is coverage, etc?
buddrousa
Zone Q - Nationwide VHF Interoperability Channels
Q1SimplexVCALL10
155.7525​
N
155.7525​
N
156.7​
ACALLING
Q2SimplexVTAC11
151.1375​
N
151.1375​
N
156.7​
AT/A for VTAC36
Q3SimplexVTAC12
154.4525​
N
154.4525​
N
156.7​
AT/A for VTAC37
Q4SimplexVTAC13
158.7375​
N
158.7375​
N
156.7​
AT/A for VTAC34 & VTAC38
Q5SimplexVTAC14
159.4725​
N
159.4725​
N
156.7​
AT/A for VTAC33 & VTAC35
Q6RepeaterVTAC17
161.8500​
N
157.2500​
N
156.7​
ALimited Availability
Q7SimplexVTAC17D
161.8500​
N
161.8500​
N
156.7​
Q8Tactical Repeater
(alternate config)
VTAC33
159.4725​
N
151.1375​
N
136.5​
AInverse of VTAC36
Uses VTAC14 & VTAC11
Q9Tactical Repeater
(alternate config)
VTAC34
158.7375​
N
154.4525​
N
136.5​
AInverse of VTAC37
Uses VTAC13 & VTAC12
Q10Tactical Repeater
(alternate config)
VTAC35Rec. for use in PR & USVI only
159.4725​
N
158.7375​
N
136.5​
AInverse of VTAC38
Uses VTAC14 & VTAC13
Q11Tactical RepeaterVTAC36
151.1375​
N
159.4725​
N
136.5​
AInverse of VTAC33
Uses VTAC11 & VTAC14
Q12Tactical RepeaterVTAC37
154.4525​
N
158.7375​
N
136.5​
AInverse of VTAC34
Uses VTAC12 & VTAC13
Q13Tactical RepeaterVTAC38Rec. for use in PR & USVI only
158.7375​
N
159.4725​
N
136.5​
AInverse of VTAC35
Uses VTAC13 & VTAC14
jmarcel66
Concord, NH
VTac36 in NH is strictly a portable repeater setup. Its only setup as needed for events or incidents by the COML or Comms folks assigned. There are portable repeaters around the state ready to deploy. The coverage varies depending where its setup.
jmfirefighter
Raymond, NH
There is actually one fixed VTAC36 repeater located on the summit of Cannon Mountain to assist with communication from one end of Franconia Notch to the other for interoperability between PD/Fire/Parks for incidents there. It is controlled by Grafton County and DOS State Police via console TRC. Default state is "repeater disable" and it is easily enabled by either agency when requested.
There is also another planned deployment for a fixed station in the Manchester area..........but it's in progress.
jmarcel66
Concord, NH
Yeah...What Josh said.
Josh, any concern, at least with Manchester if a deployable repeater is ordered in an area that might be picked up by Manchester? Or might it be "IN" Manchester minimizing the chances?
jmfirefighter
Raymond, NH
The Manchester repeater, if installed, will also be remotely controlled by NHSP dispatch and radio maintenance so it will be in a "non-repeat" state unless requested to be operational for an incident or event, which would go through the SWIC office for deconfliction.
It would be a resource in the area for any department that is in range and could use it with a simple phone call.
