vx-10 vhf
kb0zgy
Burlington, KS
Hello, I just picked up some vx-10 vhf models and would like to find the programing software if someone knows where to get it. I called vertex and they said it is not available anymore . The software is CE-14, and also is the programing cable the standard 4 ring 1/8" plug.
Rich
KB0ZGY
AK9R
Staff member
Super Moderator
Central Indiana
You can probably find the cable on eBay or buy one from RT Systems (RT Systems Radio Programming Software). The Yaesu FT-50 cable will do the job.
Search around on the web for the program. It's a DOS program. You'll need a computer that runs DOS or that you can boot into DOS. Running the program from a DOS box in Windows won't work.
Because you will be running in DOS, don't plan on using a USB port on the computer. You'll probably need a real serial port.
silverbk
You can program that model through the keypad. You can make a dongle out of aluminum foil.
