VX-180 questions
johnw06
Hi. I have a VX180 and I had it programmed by the company that programs all of our fd radios. It was supposed to be set up to dual tone fire/ems. It does not alert. I have the programming software and cable just not sure how to check or what to look for to see if it was done right. Also I was wondering how to tell if it was narrow banded properly. any help would be great
mikewazowski
Staff member
Forums Manager
Oot and Aboot
VX-190 questions
I've moved your post to its own thread since the thread you posted to was over 3 years old. Please start a new thread next time.
Thanks.
cabletech
Puget Sound
If you have the software (CE51) and the cable, then connect it up and READ the programing, and the save it to a file.
After you have done that THEN you can play with the file.
As for narrow band, the third colum is for setting wide/narrow using the space key. It should say N.
Up top under signaling, look and see if 2 tone is highlited, if it is, then this is where you set that up.
If 2 tone is NOT highlited, then the radio does not have that feature and there is nothing you can do about it.
