VX-264
Franklin County NY
Does anyone know how to shut off the BEEP in the group scan? Every time is stops on a channel it beeps and when it resumes scan it beeps. I didn't see anything in the programming. Also under group scan it does not switch to the priority channel in group 1 when receiving a signal on a different group.
MBill
On the VX-261 I believe if you select the "Common" Menu, then "Scanning" then uncheck the "Scan Beep"
box on the right side it will turn off the scan beep. Assume the VX-264 would work the same.
176002
Franklin County NY
When using GROUP SCAN the radio will not switch to a priority channel in any group while scanning if a signal is received on a non priority channel. If you use FM SCAN which scans only 1 group at a time it will. Any ideas or fixes out their?
