VX-354 programming problem..
cjh05
Hello! I picked up a vertex 354 from a buddy. I have the CE86 program. First, is this the correct program for the 354? When I attempt to read the radio, it makes my computer restart. The radio battery does appear to be bad when I turn the radio on it will show full battery bars, but when I hold the PTT button for about 3 seconds the battery bar drops to 0. Would this make my computer restart or is it more of a program software issues on my computers end?
MBill
Yes. CE86 works with the Vertex VX-450 radios. Yes. Looks like a bad battery, though I don't think it would cause your computer to reset.
Are you using a serial cable interface or the Vertex FIF-12A or similar cable interface? I've had no problems with the FIF-12A interface. Perhaps
your interface cable is not the correct one or bad.
Also check the Configure section in the Vertex Menu. You have to set it to the correct port. Also check in Windows System to make sure that
the serial port or USB connection are correct/active. Hope this helps.
PS: If you are using the FIF-12A did you install the driver for it?
