VX-4000 scan edit???
Mogman
Skidmore, TX
I have all the channels set to "U" user select scan, but cannot figure out how the user can edit the list, the user manual was useless.
I only see two scan choices for the buttons, SCAN and SCAN SELECT the scan select only allows toggling between dealer and user scan, the SCAN selection does not allow a long press selection which is where I would expect to find the edit (If it was a Motorola) I have the user scan "enabled" in the Common settings.
w6hp
LHC AZ
Did you ever find out anything on this scan issue? I'm looking for something like add/delete and can't find a thing.
Ant9270
The Green Weenie
Not sure if this is of any help, but on a few of my VX-829 and VX-924 series, you hold the scan button on the channel. That’ll allow you to scan it, or scan skip.
w6hp
LHC AZ
It's certainly worth a try. Thanks.
Danny37
New York City
Also the group up and down button in the older vertex radios when you pressed down for awhile will act as a "nuisance delete" function.
w6hp
LHC AZ
Thanks. I'll try that one too. I'm surprised there is no PF function for add/delete. There is a button insert for D/A that I have to think is for that purpose but I can't find a reference to it on any model Vertex.
