Vx 4000l not transmitng
westernme963
I picked up a pair or vx 4000l to use in band. They are the B split, aiming for around 46.xx. I had them all programmed up and they receive beautifully, but it will not transmit. When you key up it doesn't seem to do anything. Tried programming it without ctcss values with no change.
However if the emergency function is activated it will transmit solid and the mic works until it times out, so I don't believe it to be a hardware issue.
Anyone have any ideas?
westernme963
As an update. It will transmit by activating the EXT PTT on the dsub25 connector. I've tried 2 different mics, but neither of them work. I can provide a copy of my programming, or is it something that needs to be looked for elsewhere?
