VX-454 LTR receive problem
arlo
I have 2 of the newest VX-454 LTR radios. Neither radio will decode the LTR repeater. I have tried normal and inverted data and other things. The radios seem to access the repeater but the hand shake fails because there is no receive decode. The green led will give a very brief blink after PTT release. A LTR signal generator has also been tried. Also, is there a way to have more than 1 try, retries. Will someone send me a working LTR codeplug that I can review?
arlo
VX-454 LTR
I forgot to add that the repeater uses a Trident controller and Motorola and Kenwood radios work good on the repeater.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Is the correct bandwidth set?
arlo
Yes, bandwidth is correct.
ohiohonda
Looking at file i setup for a customer, it looks like I had to set the data polarity for the receive at normal and the transmit for inverted. Make sure your area code is set correctly. Also on the left side of the program is the where you input the freqs for the system but make sure on the right side of the program you set the repeaters for the correct number within the system. I will try to attach a screen shot.
arlo
Got it receiving. Is there a place to increase the handshake tries. I would like 2 or 3 tries. Thanks to everyone for the help.
