vx-9000 repeater
327skidoo
North Dakota
hey all i recently upgraded my gr-1225 uhf repeater with a vertex vx-9000u 100 watt repeater ever since i hooked it up there is a kind of whining noise in the backround so i bumped the power down to 50 watts thinking that would help (i know 100 watts is to much for the repeater it really hurts the repeater recive sensitivity it seems) anyways its powered with 50 watt astron power supply i never had the whining sound with my 1225 maybe i should have stayed with that. also it is paired with a Sinclair Q3220E-3 duplexer . thands in advance
mancow
N.E. Kansas
I wonder if the PL deviation is set too high? That can cause a whine in the audio. That is, if you are using PL of course.
fineshot1
NJ USA (Republic of NJ)
Power supplies are rated in Amps(Not Watts) and whether they have a continuous or intermittent Amp rating
and you could have a power supply that is not able to handle the current rating needed.
327skidoo
North Dakota
sorry my mistake i meant fifty amps.yesterday i went out to the site and tried a few things i tried numerous different pl tones than i even set it to CSQ and it still made the noise i took a large tractor battery (12 volt) and hooked it up to that thinking it was i power supply issue...still it made the squeeking sound so i unhooked the duplexer thinking maybe it was a duplexer noise and just spun a dummy load on than keyed it up with my hand held and the same noise. its a brand new repeater so i dont know where i am going wrong
fineshot1
With the information you have supplied i would be guessing. i simply have no idea
what you mean by "squeeking sound".
Perhaps you could record that sound and attach it to this thread?
WB4CS
Northern Alabama
Just a guess here, but is it possible that the issue is the repeater itself? It seems you've narrowed down everything else. New equipment can sometimes be bad out of the box.
fineshot1
The only other thing that comes to mind is the duplexer may not be tuned properly or perhaps with
the additional power output of the VXR 9000 that the GR-1225 did not have there may not be enough
isolation between receiver and transmit frequencies and you are experiencing the transmit getting into
the receiver.
327skidoo
North Dakota
ya i thought about that too but i have the power turned down to 50 watts i have tried a few duplexers i even tried it without a duplexer all had the same results it is still able to transmt woice there is just a back round noise very similar to the squeeling noise like when you key in a hand held and the mic in too close to the speaker of another radio on the same channel
MTS2000des
5B2_BEE00 Czar
take your duplexer out of the equation. on the bench in base (not-repeat) mode (may have to get out your VPL and program up a mode for standalone base only), does it still do it? if so, then you have a problem with the repeater itself. Good thing, Vertex has a 3 year warranty if it is bad. (all of this ASSumes you bought it new from an authorized V-S dealer).
327skidoo
North Dakota
Ok i will try that i will get my dummy loads and a hand mike to key it in thanks for the replies you guys rock
DaveTan
Milford, MA
VX-9000 noise
I would firstly check the tightness of the cabling with the duplexer. Those inter-connect cables need to be very tight... also, make sure you have good grounding to known grounds at the site.... any guess at the frequency of the whine? 60 Hz? good luck
327skidoo
North Dakota
thanks for the replies as far as duplexer cableing I have tried and even try different duplexers still got the same result as far as grounding there is a cable that g but what baffles meoes out to a ground rod outside The Shack by the tower which the county's VHF repeater is hooked up to I am not hooked in to the same ground as them but what baffles me is when i hook up my motorola or Kenwood it works fine
DaveTan
Milford, MA
Based on some recent experience, you might want to turn down an adjustment called "repeat sensitivity" on tab 2 of the alignment screen in programming. Don't turn down too much or you will lose voice loudness in your audio output on transmit...
327skidoo
North Dakota
thanks for the info if I remember right I tried but it said dealer mode only or something like that does that sound familiar? it's basically locked out of parameters and would not let me adjust to them
