VX-P820 series program ?
Seymourmtn
Seymour, Tn
Greetings
I have inherited a P829
The software is somewhat odd and I find the operator manual doesn’t include much either.
well, I digress, so here are couple questions that you all may be able to help with.
1. I would like to SKIP particular channel and have it still stay skipped until I unlock it. So far I can skip it but when the radio powers back on the channel isn’t skipped.
2. How do I permanently delete a channel either vis the radio or software?
3. I am getting ‘trailing’ squelch on a lot of P25 channels, especially.
Thanks for any help that can be offered. Happy Thanksgiving
Doug
Ant9270
The Green Weenie
Set your tail squelch elimination to 180ms for the squelch tail at the end. To delete a channel in the CPS, you need to click on the number on the side of the personality and it’ll “gray” it out and no longer show when the radio is written.
Seymourmtn
Seymour, Tn
Thanks for the info. Easy on the deleting a channel. But, I am not finding the tail squelch setting.
Happy Thanksgiving
Ant9270
The Green Weenie
Common ==> Miscellaneous ==> CTCSS Tail Elim
Set that to 180deg. That should do the trick.
