vx3000 tx issue
warr1974
Anyone experience an issue where the unit will not transmit if the applied voltage is below 12.06V. At voltages below 12.06 during transmit the unit will show low power with the wattage pulsing and the current shows pulsing. At any voltage above 12.06 the unit transmits fine. This voltage is measured at the point on the radio where the power cable connects to the board. All solder connections look good.
Any Ideas?
m-gerty
Miiddle TN
What are you using for a power supply? How much current can it supply? Usually mobiles are rated for 13.8 volts and the current is dependant on the radios power output, usually around 20 amps.
warr1974
My test power supply is adjustable and capable of over 20 amps. this radio draws less than 10 amps at max power. So power supply doesn't seem to be my issue. From what I am hearing this Vertex radio just doesn't like any supply voltage at less than 12.0 Volts.\
