vx354 narrow banding
WSCU375
Gainesboro,TN
Can anyone give me a step by step instruction on how to go from wide band to narrow when programming a vs354 the software came from the anntena farm if that helps thanks
wa2chj
Charlotte, NC Metro
VX-354 Narrow banding
With the software from Antenna Farm, go to the column maked W/N, and double click in the row you want to change. The software will cycle through W5, W4, and N. If you select "N", that channel will be narow band.
wa2chj
Charlotte, NC Metro
As I said, the one marked W/N between Pri and TAG. Space Bar will cycle through the options. Check the Help Topics for W/N.
