VX450 MDC Beeps not normal
notmyj
I have a VX 454 and 459 I have programmed to use here at work. It took a bit or reading but I was able to get the MDC set up so that each radio was able to send the ID through the repeaters back to dispatch.
Everything is working on them as it should, but one thing that bugs me is the Beeps that are transmitted after/during the MDC data. Normally I hear the tell tale squawk from the other radios on our system. The 454 and 459 have these beeps.
The radios are set up to ID Pre PTT. When I push the the PTT I get a pause, then a beep to signal the MDC has been sent. On all recieving radios you hear the following.
Any ideas on why it sounds like this and not the normal squawk? Or how to change this? I am using CE115 and there isn't a whole lot of help online with this....
  • Vertex MDC Beep.zip
