VX6000 power output
kb1ejw
Local Idiot
Western Hemisphere
Hello- I installed a VX-6000 VHF for our local schools for their bus base station operations, and I can't find a way to adjust the transmit power, other then "high/ low"
The spec sheet says 110w adjustable to 5w.
I was under the assumption there would be different steps, i.e. 50, 25, 10, 5..... not just 110w & 5w. That's a huge difference. Motorola, you can pop in any wattage you want so long as you don't exceed the set limits. I've looked all over how to change the wattage, but I don't see anything to change steps other then High/ Low. Anyone have any ideas? We're licensed for 45w output & 15 ERP (I didn't do the licensing, it doesn't look right to me but I think I know why it's like that) So I don't want to TX at 110 and kick out a nearby station (hence the low ERP in the license) .. plus the power supply would be at its operation (but not peak) limit. I rather keep equipment cool and run lower power.
Thanks for any help
Jeremy
jeatock
090-45-50 W, 39-43-22 N
Been there, done that.
The standard CE49 software only lets you select TX power from High and Low. Defaults are 110 and 50 watts.
To change or define Tx power you need a special FIF-8 programmer (different from the normal adapter) connected to the RF deck DB-25. THEN you need SVC49 alignment software to define power output at High and Low.
While you are at it, check the actual narrow modulation. Nearly all of the VX6000's I've worked on will put normal voice well over 2KHz deviation. Excited firefighters run over 3KHz and become unintelligible. It's all trial and error, and requires a good service monitor. Still, a right decent radio once you get it adjusted.
kb1ejw
Local Idiot
Western Hemisphere
Ugh well that's just great LOL
Thanks for the info.. I was hoping it'd be a little easier then that.
