VX82X/92X
radiotweester
Oregon
DON'T screw with the firmware for W/N!!! Get the Wide Band Recovery Tool. It's another freebie that was developed for International, Marine, HAM and anybody allowed to use 25k. What CE59 software version are you running?
The frequency limit thing for MDC sounds weird. You could try Windows enabler and tweak Common-> Hardware to a lower freq, but the problem sounds more like a version issue. I don't know if a call to Yaesu and not Motorola would yield any results on the 470-512.
lookforthe1
Where can I find this???
lookforthe1
where can i find the wideband recovery tool? and i have the most recent cps ver
radiotweester
Oregon
I believe it's on the Motorola's Vertex site? It can be found online too. It's a tiny little application. I have a couple versions of it on another computer. I will look. You just send it to the radio once and it turns off the narrow only flag. As it was free and is not programming software that was ever sold by Vertex, I think it's ok to post here?
lookforthe1
check your inbox
lookforthe1
i found it nvm
radiotweester
Oregon
Ok. Well if anybody else needs it for HAM, GMRS, NOAA WX, Marine, etc. Again, it was NOT a product that was ever sold and is only for allowing "wideband" W5 or W4 to be programmed after the 2013 FCC narrowband requirement.
Instructions - attach the regular programming cable to radio and computer, select your radio and press Execute. This should only need to be done once per each radio. This is Version 1.03.
*Remember* normal 150-174 and 450-470 is "narrow" N FM .
  • Wide_Band_Recovery_Tool_1_03.zip
