Wall wart help
ampulman
South Jersey
I guess I tried to stretch the power cord for my PRO-160 too far, as the plug separated from the cord.
Of course, I can't lay my hand on instructions so I'm guessing that with the + on the plug lined up with the flat on the cord, the center conductor is positive, as indicated on the radio.
Will a kind soul please verify that I'm right.
Thanks.
Amp
ampulman
South Jersey
positive. Some times you'll find the reverse to be the case. If it's marked +, then you're correct.
I'm 99+% sure it's + center pin according to the diagram on the radio. The RS supplied wart can be configured for + or - center conductor. What I'm asking is whether the 'flat' on the cable is the indicator for + or - .
Amp
wtp
Port Charlotte FL
sorry about the size
- -c.- +
if you can see the decimal point and raise it a little and see that on the side of the radio that is a positive tip.
think negative sign dash c for outer connector decimal for center dash and +for positive.
the radio might have it flipped around but you will get the idea.
ampulman
South Jersey
- -c.- +
I'm sorry, but I'm not following you with regard to the decimal point. Yes, I have determined (with 99% certainty) that the center conductor (radio) is positive.
For the sake of clarity, let me restate my question: it really centers around the Radio Shack wall wart. The cord ends in a 2-pronged socket which is not polarized. The user selects the appropriate plug which can be used with multiple equipment in either + or - center conductor mode. The mode is chosen by flipping the plug 180 degrees.
There is a 'flat' on the end of the cord. Does this serve as the point of reference with the +/- marks on the plug? The plug has pulled away from the cord. This is my problem.
Thanks.
Amp
jim202
New Orleans region
Thanks.
Amp
Don't you own a volt meter? Use of the voltmeter will let you know what polarity you have.
ampulman
South Jersey
I had tested the socket on the line (DUH), not the plug. Tried it, and the center connector is positive--scanner working.
Thanks.
Amp
