>> Rebanding is the "adjustment" made to accomodate the IDEN networks of Nextel and SoLink. This will alleviate the interference problems.
Actually, rebanding is being done to accomodate public safety users. Rebanding does nothing to improve Nextel's operations on 800 Mhz., except add additional expenses to their already dismal profit / loss statements.
Even after your favorite local agency makes the transition, there may well be interference issues from other agencies who have also moved to some of the same frequencies, as well as agencies who have not made the transition. The greatest potential for interference may likely be near state borders.
Rebanding will also benefit public safety by including the splinter frequencies in the channel assignment plan. That's why the channel assignments for each frequency will change. Without radios that could read the new plan, public safety could not take advantage of narrowbanding - and the extra frequencies - available to them.
>> My question is, let's say you reband to be able to listen to Walton Co...but Atlanta is not rebanded? Will your scanner be able to simultaneously trunk-track rebanded and non-rebanded systems?
The Pro 96 / 2096 appear to be able to accomodate this, as you can manually enter custom tables. With Win96, you can enter 6 (?) tables. In theory, you might use the custom tables to program the rebanded system, while programming a system that has not yet rebanded as you do now.
If Radio Shack offers a new chip to accomodate rebanding, and you send the scanner in for the upgrade, you may still be able to use the custom tables for systems that haven't made the transition, or never do ... ex - a business that doesn't qualify for rebanding compensation, and only uses its radios intrasystem.
It will be interesting to see if the two new top-tier GRE scanners - expected this fall - will carry over the custom table feature from the Pro 96 / 2096.
