WARRS coweta heard carroll countys
t0xPro-197
Maggie valley North Carolina
thanks i try too give the best feed i can just wish i lived higher up then it would come in alot clear and i could actually get more but im glade it sounds ok im getting better at this as i go
jturner0829
Georgia
I have made those changes you said below. Couldn't tell any difference with the reception. As far as the CCs I only have the 4 both red and both blue. There is only 1 tower in my county but from what I have looked at it uses them all.
Is there anything else you see that I could try?
I'm going to make a couple of observations. First, since the system is simulcast, only use the CC's for the tower site closest to you. Second, change the multisite mode to OFF. Over the years with my 106 and 197, I found this to be the best setting.
HTH,
Larry
DC
Carrollton, Ga.
jturner0829,
You only need to have the Carroll County tower in your radio, that is unless you are listening to Coweta as well.
852.8625 - Primary
852.1000 - Alternate
Also, adjust the global settigs as such:
Type: P25 Auto
Multi-Site: Roam
Threshold Hi: 95
Threshold Lo: 30
T Tables: Default
Hope this helps.
I live just across the county line in Carroll County and I get good reception of Heard. If this doesn't help you can contact me at (334) 646-0239 and I will arrange to meet with you at the Dollar General in Roopville to take a look at your radio and see what I might can do to help you.
Happy scanning, DC
jturner0829
Georgia
Thanks DC
Ill try that out when I get home. Sitting here at the station now waiting for a call. Ill let you know how it works out.
jturner0829,
852.8625 - Primary
Type: P25 Auto
Multi-Site: Roam
Threshold Hi: 95
Threshold Lo: 30
T Tables: Default
Hope this helps.
Happy scanning, DC
jturner0829
Georgia
I changed setting and seems to do some better. I'm hoping one day they will get our radios fixed and issue them Back out to us. Thanks for everybody's help.
