Washtenaw Co., MI Scanner Test
BuiltonAsus
I am trying out Streamwebtown.com servers to see if I can stream my scanner and listen to it while I am at work. I will be leaving it up tonight. Any feedback would be great if you can listen in or not.
http://streamwebtown.com/washtenawareascanner
Place this link into Window Media Player by pressing Ctrl + U; then enter in the address above.
BuiltonAsus
It may not load correctly in your webpage. You may have to enter in the address into your media player manually.
rcvmo
Romulus, Mi.
No, I meant nothing WAS happening at 0-dark-30 hours.
I like to give you my A2 dept.'s channel(s) , but i'd have to get authorization form the powers to be.
rcvmo
NYRHKY94
Brunswick County, NC
Working fine for me in WMP. The audio is only coming thru on 1 speaker, so I'm assuming that's the way it was set-up.
Thanks - Mike
BuiltonAsus
rcvmo, thanks for the clarification, I didn't read that carefully. I did add some AA public service talkgroups already, but as you said you needed authorization. I guess I am not clear on the law of posting a scanner on-line. I was mearly testing it out. Let me know if this is problem and it will be taken down.
NYRHKY94, Unfortunately if I plug in the audio jack in the whole way I get a horrible feedback sound, so I have to back it off a bit which in turn I loose the stereo feed.
