Waterloo Regional P25 System
rkillins
Kitchener, ON
I listen to this new system frequently and have never heard activity on 1079. That TG was put into the database at the same time some other inaccurate talkgroups were added (ie there are no fire station specific talkgroups TMK), so not sure if 1079 is reliable. Rely on TG1000.
CDTbolt10033
Waterloo Region, ON
Yeah no activity on DEC: 1079 I'd say DEC: 1000 is the Township Fire Dispatch.
I have my Uniden BCD996P2 set up like a fire pager so when there is activity on for example Maryhill Fire: 1709 the scanner alerts when there is activity on that specific TGID.
Another example would be St. Jacobs Fire: 1711 and for St. Jacobs Medical: 1712. These TGID's are only active for calls/pager tests. Also, the Dispatch 2 channels for Kitchener Fire Department, Waterloo Fire Rescue, Cambridge Fire Department are back up dispatch channels.
CDTbolt10033
Waterloo Region, ON
So I did some more listening on Monday and what was supposed to be Cambridge TAC 1, I was hearing Elmira doing training. When Cambridge uses a Fire TAC channel its either one of the Regional Ops channels or TAC channels, not the Cambridge TAC channels.
Not sure that those Cambridge TAC channels are for. Anyone else know what those channels really are?
rkillins
Kitchener, ON
Referring to TGID 1021 - 1026? I have no idea what those are ... they are not TAC channels and honestly ... I've never heard them, so for TAC channels, they aren't put to good use. There were some similar Kitchener and Waterloo channels that were station specific, which were flawed because they referred to stations that didn't exist (like Waterloo Stn. 6). They've been removed because I don't think they were were proven.
AFIK, all Regional Fire Services share the TAC (1-5), OPS aka Fireground (1-5), and training (1-5) channels. Dispatch will assign a call to an appropriate channel. It's not uncommon to hear the Township services ask Dispatch for a Training channel to use. All up to Dispatch's discretion. I'm not quite sure if their is any rhyme or reason as to the use of Fireground vs TAC channels. They seem to use both routinely and interchangeably.
Forts
Ontario, Canada
Yes absolutely! It can then be added to the database or wiki as needed.
As for whether or not FD will encrypt... My personal thought is that if they were going to, they would have right from the get go. But who knows that the future holds, especially if they don't like people streaming their traffic.
CDTbolt10033
Waterloo Region, ON
The township FD's Pager TGID's these ID's are only active when they are testing pagers or there is a call for an FD.
Township Dispatch/Paging is on TGID/DEC: 1000
Entry No.Paging TGIDFire DeptPager Alert Type
11401AyrFire
21501LinwoodFire
31502LinwoodMedical
41503LinwoodOfficer
51504St.ClementsFire
61505St.ClementsMedical
71506St. ClementsOfficer
81507WellesleyFire
91508WellesleyMedical
101509WellesleyOfficer
111601BadenFire
121602BadenMedical
131603New DundeeFire
141604New DundeeMedical
151605New HamburgFire
161606New HamburgMedical
171701BreslauFire
181704ConestogoMedical
191703ConestogoFire
201705ElmiraFire
211706ElmiraMedical
221707FloradaleFire
231708FloradaleMedical
241709MaryhillFire
251710MaryhillMedical
261711St.JacobsFire
271712St.JacobsMedical
VA3ADP
Mississauga, Ontario Canada
I totally agree with you. If it hasn't been done by now, it's not going to happen. (Knock on wood).
Andy_SDS100
Seen a new talkgroup come through this evening very active, TG3607 with theese unit id's 3516005, 3516004, 3516010
Andy_SDS100
I believe I ran into that TGID: 3607 it's encrypted so it must be Waterloo regional police.
Correct It was encrypted, I did hear on Transit side giving a description of someone, maybe it was Transit Enforcement like Air11 said.
rkillins
Kitchener, ON
I believe Transit Security may still be on the old EDACS system with the other transit talkgroups at this point, unless things have just recently migrated over.
rkillins
Kitchener, ON
When do you find them commonly testing your pagers? If I recall, it used to be Monday evenings. I haven't logged these talkgroups yet on DSD+ but I'm clearly not monitoring at the right times.
CDTbolt10033
Waterloo Region, ON
Usually, I hear them start testing around 6:30 or 6:40 and go on to 7 pm on Monday. Also, Elmira will come on Saturday close to Noon usually...
