Weather / Storm Frequencies for Tulsa
rvacs
Tulsa, OK
Hello All,
What frequencies should I put in for listening to Tornado Spotters / etc. in the Tulsa Area?
I have so far:
146.880
146.940
443.850
Thanks,
Rich
safetyobc
South Arkansas
This is what I have for NE Oklahoma
Tulsa NWS 443.8500
Creek Co Link 442.0000
Cherokee Co Link 442.2250
Muskogee Co Link 443.1000
Okmulgee Co Link 444.6000
Mayes Co Link 444.8750
Barlesville Area 444.9750
Ponca City 146.9700
Bartlesville 146.6550
Bartlesville 146.7600
Vinita 147.3600
Tulsa 146.8800
Tulsa EOC 146.9400
Broken Arrow 146.9100
Claremore 147.0900
Pryor 147.0600
Chandler 147.3600
Tahlequah 147.2400
Fayetteville AR 146.7600
Muskogee 146.7450
Preston 145.3100
Okmulgee 147.2250
Wilburton 145.3300
Ft. Smith AR 146.6400
Chandler Cvl Def 155.8200
Mutual Aid SOs 155.7600
Mutual Aid SOs 155.4900
PDs SOs Common 159.1500
PDs SOs Common 155.6700
Tulsa Rptr Org 146.8050
Tulsa Rptr Org 444.1000
Tulsa Rptr Org 444.7250
Tulsa Rptr Org 444.9500
Tulsa Rptr Org 421.2500
Bartlesville 444.7750
Bentonville Area 442.8500
Tulsa SKYWARN 147.3900
Tulsa SKYWARN 147.0450
Daisy SKYWARN 444.4000
safetyobc
South Arkansas
Also so general freqs I have is
National Storm Lab freqs
Ch 1 Mobile Wx 163.1000
Ch 2 Mobile Rptr 165.4350
Ch 3 Secondary 163.2750
Doppler Vehicle 151.9400
Dunno what they are or if they are in use?
Then there is the OK Emergency Management freq 155.2350
Also Amateur Storm Chaser Freqs.
Amateur Chaser 146.5500
Alternate Ch 146.4600
Simplex 223.5200
Simplex UHF 446.1000
Simplex Alt 446.0750
Simplex 1294.5500
KD5WLX
Tulsa
443.85 is the TARC UHF linked system - go to www.w5ias.com for a map of all the repeaters in the system (with their status). NWS uses it to talk to stormspotters in the field for any weather event.
If the storms are in the "immediate" Tulsa area (including surrounding counties, but not (for instance) when they're off by Grand Lake then they also man the second desk, usually on 146.88. TAEMA takes damage reports at the EOC on 146.94. If either VHF freq has a problem, backups are 147.39, 147.045, and 145.11 (pretty much in that order).
In some cases, 147.045 may be "simulcasting" the UHF side, but that link is one way (receives from 443.85, but if you transmit on 147.045's input, it's only repeated locally - not re-transmitted over the UHF system.
Most of the 2m freqs (outside those already mentioned) will either be the local repeaters the outlying EOCs use to talk to spotters without UHF capability - the EOCs then relay the reports through the UHF system. The VHF freqs in Tulsa (and some that aren't) aren't really "weather" freqs - they're just local Ham repeaters (and the list provided in the earlier post is far from complete) - they may or may not have weather related traffic on them. Some most definitely will - used by outlying EOCs (147.06 in Prior is used by Mayes Co. EOC, 147.24 in Tahlequah by Cherokee Co. for example) for "relay" purposes. Others normally won't (146.805 is a TRO repeater, but its coverage is limited, so it's down about #6 on the "backup to the backup" list. Doesn't mean it won't be used, just that it won't be used "all the time".
Also, the ones that are regular amateur radio repeaters or simplex freqs (that would be all 144-148MHz and 440-450MHz) will be used for "normal" amateur traffic (whatever that is) when there is no active weather.
CommShrek
peterjmag said:
The last few events in the Tulsa metro have been 443.85 and 147.045 linked together. I guess 88 is not 100% and 94 is still down?
P.J. Maguire
That is my understanding. However, TRO seems to be aware of the problem but as with everything, finding time and resources to fix the problems are sometimes tricky. Upkeep of the .94 machine gets blocked by the tower owner at times. Some of the .88 issues will involve some tower climbing and also some instalation of some new repeater packages. I'm confident that things will get better soon. I also think it'll take more time than most folks want or realize to accomplish.
KD5WLX
Tulsa
To add what 2B said - 94 is "intermittent". The power supply crowbar (overvolt protect) trips it off if nearby lightning puts a surge on the line. Cycling the power resets it, but that can't be done remotely. However, if the whole tower loses power, 94 comes back up when the power does.
Unfortunately, that means it's unreliable when you need it most - the lightning with the storms is what gets it when we need it most. For the time being, listen for the EOC on 147.39 if 94 is not there, and TARC will be linking the one-way to 147.045 from the UHF side when the storms are close. The "fix" for 94 is ready to go - once they can get up the tower.
88 is much better with the north receiver installed downtown.
