Weird error in SDRuno
Spleen
Baltimore, MD
Were there any plugins running? Or were off and you started it or were on and you closed it? I got that error once when trying to sync CloudMarkers. I shut down SDRUno and restarted it, then opened Cloudmarkers and tried to sync it again and it worked fine. I called that just a glitch...
LimaZulu
That's an error where usually only the developer can trace back and fix as these sort of errors are "created" when writing the code :)
A simple "turn on this" or "turn off that" would not help you :) So, please report back to the dev team with the error message as well as what the conditions were when you saw it.
