Weird issue
Cheeseburgers
I was editing a system, CSERN in CT. I assigned quick keys to two depts. Assinged 0 and 1. Then it said nothing to scan... super odd behavior. Never have seen that... when I removed the quick keys... it started scanning those two depts again...
I'm using an SDS 100...
No conflicting sys quick keys as far as I know....
Thoughts?
garys
Central Texas
One other thing to check, although it was not the OP's problem is to make sure that the correct Service Type is set. I generally try to build my systems from scratch, sometimes starting with a RR download, but adding information manually as it becomes available. ARC536 defaults to Custom 1 if you don't set it manually. I've been caught by that bug a couple of times.
