what can i get if???
VPD24193
NJ
i am curently running a non-digital scanner. I have all fed freqs programed all i get is encryption. what could i get if i got a digital scanner. i live in NJ 20 min from NYC
D
DaveNF2G
Guest
If everything is encrypted, then a digital scanner won't make any difference.
Squad10
If you got a digital scanner, example GRE PSR-500, you could tell if a transmission is encrypted or not encrypted. If what the scanner receives is encrypted, it will be unintelligible. If what the scanner receives is not encrypted, you will hear voice.
KB1JHU
Milford, CT
What you are hearing is probably not encryption but the digital modulation. If you pick up one of the digital scanners available, you'll likely be able to get some of them but there probably some that will be encrypted.
ampulman
South Jersey
Need that digital
I'm down in the southern end of the state where there is a lot of P25 stuff (out of Philly) to be had. Also, a lot of encryption (you will hear enc. and non-enc. on same channel).
Some analog also.
Amp
