BCD436HP/BCD536HP: What do these Settings Mean & Do?
kh6sz
Gulfport, Ms
I'm using a BCD436HP and when I do the FUNC + Scroll knob push, it brings up something on the bottom of the display.. It shows:
ERR:--- 8 AUTO
T 1.36 1.62 1.88
I don't think I've ever seen anything display for ERR, but what error is it referring to?
I have all my systems and digital conventionals set to Auto and 8. The 8 and AUTO on the display seems to change as it is scanning. Sometimes the AUTO will switch to MAN and the 8 will switch to something else, usually between 6-13. Is this what it should be set at for each system to receive the best?
Now to the T numbers. These are constantly changing, but I have no idea what they mean. Acts like a low, medium, and high limit, but for what. Is larger the number the better, or the reverse?
If someone has any definitions of what they all are for, in laymans terms, I would appreciate it. I think it's a tool to help zero in the digital threshhold, but without knowing what everything means, it's not alot of help.
Thanks in advance.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
My link above should go directly to that section of the manual.
Sent from my Pixel XL using Tapatalk
Sorry about that. Maybe if I had let it load for two seconds, I would have noticed. :roll:
(Tiptoe-ing out of the room slowly backwards)
KE4ZNR
Radio Guru
It is all good :D I should have been more descriptive (darn tapatalk and their way of linking) and I appreciate you catching where I was slack :)
Marshall KE4ZNR
kh6sz
Gulfport, Ms
Thank you both KE4ZNR & mciupa:
I learned a lot from that. I didn't know it was only for P25. I bookmarked the easier to read manual.
Thanks again.
KE4ZNR
Radio Guru
Thanks again.
No worries. There are so many settings in today's radios that it is tough to remember them all.
Happy Monitoring
Marshall KE4ZNR
jonwienke
More Info Coming Soon!
VA
Thanks again.
It's actually applicable to DMR and NXDN as well.
kh6sz
Gulfport, Ms
Thanks jonwienke:
That's what I was thinking, but the manual said it was a P25 adjustment mode. I have all of my systems set to Auto and 8 and most are working great, just a few that I'm going to tweak a little.
jonwienke
VA
Thanks jonwienke:
The manual was written before DMR or NXDN were released, and was never updated. It should probably be re-labeled "Digital Adjustment Mode" given that it is not exclusive to P25.
