What Is "DMR (MOT)"?
CanesFan95
Was Homeboys-Scanna
FL
DSD+ Fast Lane is showing "DMR (MOT)" in the Event Log footer. Anyone know what this means?
kc4mc
Crescent, OK
I saw this DMR (MOT) as well and wondered the same. But if its Trunk Mobile, Motorola is either Cap+ or Con+. Does Motorola have something different than these two for Tier 3 systems? Maybe something prior to Con+?
kc4mc
Crescent, OK
Thank you sir, but this doesn't necessarily answer the question. There are voice transmissions on the DMR (Mot) system as well, not just radio checks. Here is a snip from the decode logging:
Activity update: Slot1=No Activity Slot2=Indiv Data
+DMR slot2 BS DATA DCC=8 CSBK [LB=1 CSBKO=41 (?) FID=10 v16=0325 id1=4787460 id2=16515072]
29 10 0325 490D04 FC0000
101010010001000000000011001001010100100100001101000001001111110000000000000000000111000111111101
+DMR slot1 BS DATA DCC=8 Idle
+DMR slot2 BS DATA DCC=8 Data Header DPF=[2:UcData] Tgt=16448250 Src=206050 Conf=0 SAP=[9:prop] Blocks=4 Pad=11 Last=0 Seq=0
+DMR slot2 BS DATA DCC=8 Data Header DPF=[15:prop] SAP=1 MFID=16 1F 10 02 01 11 95 1E 0D 16 22 99 8D
CanesFan95
Was Homeboys-Scanna
FL
Post #3 in that thread is about the closest to an explanation. So is Capacity Max the same thing as Tier III, or is it Motorola's proprietary ver$ion of Tier III? And therefore does "DMR (MOT)" mean Capacity Max?
The poster said "obviously", but I don't see how this is obvious without asking.
clbsquared
Isle of Wight County
CanesFan95
Was Homeboys-Scanna
FL
But usually, DSD+ will display "DMR", "Cap+", or "Con+". So is "DMR (MOT)" something different?
CanesFan95
Was Homeboys-Scanna
FL
Usually, when that happens (which I see/hear all the time), DSD+ just shows "DMR".
EricCottrell
Boston, Ma
Hello,
DSD+ is indicating DMR (MOT) because the MFID in some of the headers is 16 (Motorola) instead of 0 (DMR Standard). A MFID of non-zero indicates proprietary data.
A Hytera T3 system has both DMR Standard and Hytera Proprietary data. A Motorola T3 system has both DMR Standard and Motorola Proprietary data.
Connect Plus systems use a MFID for Trident Microsystems because they developed it.
73 Eric
