What is the best "MOBILE" scanner antenna?
spdfile1
/\/\ Junkie
Port St. Lucie,FL
I know this is a broad question but here is my situation. I have a Radio Shack Pro-2051 mobile scanner hooked to a Radio Shack mag-mount mobile scanner antenna (cat. #20-032) all on a 2007 Chevy Impala. It is starting to rust out where the element screws into the base so I will be replacing it. On the antenna I have now I am only using the top element because it is the correct length for monitoring the railroad band (160-161 mhz). That is what I primarily listen to but find it picks up well on all bands. I want some input on what people think is better as I know the one I have from radio shack is not the best even though it works well for me. Also I mount it in the center of my roof so to get the best ground plane effect. I'm not going to spend hundreds of dollars but may be willing to go as high as $200 (if the wife allows)!!!!!
jdcmix
Easton, Md.
I just recently purchased an Austin Spectra multiband antenna and am very pleased with its performance. I also use an Antenex 14" stainless whip that's tuned for 136-174mhz. It's a NMO mount that I have on a piece of fire apparatus that I've restored, and it does a great job on vhf high. The Austin IS a bit bulky, so if you prefer a low profile public service style antenna, the antennex is perfect. Got mine on Ebay for 9.95 and free shipping. It's available with mag mount as well (higher price though). That's my 1 1/2 cents worth.....
chanerz
San Francisco CA
If you want low profile go with SpectrumForce Wideband Antenna with Mag Mount and BNC. I have the Austin Spectra also and love the performance.
commscanaus
Melbourne VK
The Laird/Antenex ABSCANC with optional spring works well for me.
Mounted on the luggage rack, it is used to scan 160/420/860Mhz and does perform very well on all those bands. It is connected to a Uniden 996T.
These antennas can be had from around $40, are reasonably low profile and fit any NMO style base.
Mine has been struck by the overhead gantry's in a number of underground parking lots and is undamaged.
Commscanaus.
prcguy
If all you need is 160MHz railroad it would be hard to beat a Larsen 5/8 wave NMO-150 mounted in the center of the roof. Its fairly long at 43" (cut for 160MHz) but flexible and if you want more gain be prepared for a larger antenna.
prcguy
n5ims
The "Best" antenna for you may be a combination of several that you swap out as needed. Just make sure that they all use the same type mount and swapping will take only a few seconds (recommend the standard NMO since that's what many use). Since you're mainly interested in the railroad band what I'd recommend is this:
* a standard 1/4 wave whip cut for your main frequency (see the manufactur's instructions for the correct length). This will be rather short (about 16" or so) and work well, but provide no gain.
* a 5/8 wave whip with loading coil such as the NMO-150 already recommended. It's rather long, but will provide you additional range since it has some gain.
* a multi-band antenna such as the Larsen tri-band 150/450/800. It's also fairly short (about 19") and covers the most popular scanner bands well.
Getting all three, including the single mount should be well within your $200 price limit and provide you with flexibility as well as some form of backup if one gets damaged.
spdfile1
/\/\ Junkie
Port St. Lucie,FL
I appreciate everyone's response!!! I was hoping to get several and compare the results. The only thing I should have mentioned originally is that I prefer using bnc as it is most readily available but i'm sure connectors will correct issues. Also I prefer mag mount's versus drilling into the roof. I've noticed a few antenna's brought up more than once so I will be closely looking into those. Again thank you for everyone's response and those who will be responding.
n5ims
I hope you're not talking about something like this Larsen BNCMMBNC BNC-BNC mag mt, portable | TESSCO since that would force you to use low gain and poorer (if that's really a word) performance antennas designed to connect directly on the handheld radio.
What you should get than is something like this Ham Radio Outlet | LARSEN NMO-MM-BNC | NMO MAG MOUNT W/ BNC CONNECTOR where you would use normal NMO mount antennas to attach to the mag mount base and plug it into your scanner using the already attached BNC connector. This would allow you to use any standard NMO mount antenna as discussed earlier on the mag mount base.
spdfile1
/\/\ Junkie
Port St. Lucie,FL
n5ims,
Yeah thats sounding like the best way. I got nmo confused with something else.
Ensnared
Waco, Texas
Wide Range
I don't want to spend Austin bucks right now. But, I am surely interested in the Spectrum Force. So, how well does the Spectrum Force work on low band?
Ensnared
Waco, Texas
I have decided to buy the Austin, but I will buy it in two phases so that I can afford it. I will buy the antenna and then the Larsen magnetic mount.
