BCD436HP/BCD536HP: What is the OUTPUT of the OEM original BCD536HP AC power adapter ?
rbluesky
Would some please post the OUTPUT of the OEM AC power adapter for a BCD536HP
Need voltage and Current (amps) PLEASE
RMason
Colorado / Mississippi
The AC adapter supplied with the BCD536hp is an 13.8V, 750mA AC adapter. The equivalent OEM adapter is AD-1009 from Uniden.
Uniden AD-1009 AC Adapter | Scanner Master
Thank you I have a 13.8volt 750 MA the current seems to LOW
13.8v / 750mA should be sufficient if it is well-regulated. What supply are you using? Is it AD-1009 or something else?
gary123
A higher amp output is fine as long as the input voltage is correct (13.8). The scanner will pull as much amperage as it needs. Its better to have to much amperage available rather than not enough. Think of it like a car engine 4 cylinders may be fine but its better to have V8 hemi LOL.
wtp
Port Charlotte FL
images
images
both are 12 volts....which do you think will run your radio longer.
the voltage is very important. too much and the radio might get fried.
but for current (capacity) the more, the better.
rbluesky
That is what my factory PS shows. I would use a VOM and measure the Current draw of the 536 as I run 6 536's off of a 12 Volt DC 5 Amp PS.
Hi Could I run ONE BCD536 off a 5 amp supply at 12 volts ???
That's what I have AD-1009 the display doesn't seem very bright must be the LED's
Right that's what I have been told Thanks !
