What is VIPER?
E-542
Lancaster, PA
What exactly, is this VIPER system I keep hearing about? It looks -seriously- complicated to program according to the database here, and I'm not sure exactly what the plan with this system is. What's it do? what's it for? Who uses it? Why? Etc.
Thanks.
n5ims
It (Voice Interoperability Plan for Emergency Responders (VIPER) Trunking System, Various, North Carolina - Scanner Frequencies) is a state-wide radio system (similar to those in various other states) where state, county, and local agencies share a common system. It allows a way for the various agencies to communicate as they might using seperate systems, but also allows an easy switch to common channels during emergencies where multiple agencies need to communicate. In theory, at least, there may be a cost savings since the expensive infrastructure is shared by many agencies and radios or equipment can be purchased in larger quantities resulting on larger discounts.
A few things you need to remember when you're programming a scanner for the system:
* Program in only the site(s) that are nearby (if you travel, "nearby" might include those you travel through as well). Generally, you only need to use the one or two closest sites since the signals for those far away won't be picked up anyway. If you have sites programmed in that are out of range, you may want to lock them out to speed up your scanning.
* You'll only hear transmissions for talkgroups that are "affiliated" with the site you're currently monitoring. If someone in that site's coverage area is on a talkgroup you'll hear them, if not you won't.
* If a transmission is encrypted, you may hear digital noise, silence, or it may keep scanning (which one depends on how your scanner handles encrypted transmissions).
E-542
Lancaster, PA
Ah, thanks. That's led me to discover A: Home county of Cabarrus is on VIPER, and B: I'll need something like a PRO-106 since I got a PRO-164 and the talkgroups are listed as Digital ones. Dang...
n5ims
E-542
Lancaster, PA
Ah ok, thanks again. I apparently just won't have anything to do with VIPER till I can upgrade to a Digital scanner, hah...
KE4ZNR
Radio Guru
KM4WLV
Rockwell (Rowan County), NC
E-542 (and anyone else wondering), VIPER will not serve as a replacement for the Concord/Cabarrus system. The Concord system is supposed to become part of the regional P25 system with Charlotte (or at least last time I heard). VIPER is somewhat active in Cabarrus County, mostly with SHP traffic.
I just didn't want you to think Cabarrus was jumping ship to VIPER.
kd8x
NC
Concord PD and Cabarrus Co. Sheriffs do use Viper for drug surveilance etc and special ops etc.....Not an everyday thing but they do use it enough to have it on your active scan list....
