What Motorola gear will work on the ham radio 33cm (900 MHz) band?
KC2GSP
MTX9250 work very well. I have some available if there is interest. Also some of the efj 5100
Would you be able to assist me with the part number for the antenna on the 5100? I have one that I play around with on 33cm but it's now weathered and cracked. Only replacement I can find is for the 800 mhz radio and the antenna connector color is not a direct match
n3obl
Ø
PA
I do not. Could try calling ef johnson and ask for technical support and see if they can locate a part number and if they still have available. I would use a motorola 900 antenna from jedi if unable to find a match.
ergbert
FN22
I haven't seen any EFJ 5100's in 900, only the ubiquitous 700/800 ones. I've got a few (7!) UHF-380 versions though. Do the 900's turn up often or do they get mislabeled as 800's?
KC2GSP
They turn up time to time from what I've seen, may need to set an eBay alert
