Rescue947
I’m sorry to bother anybody but what scanners does everybody use to monitor Ohio Marcs
The same is true for Belmont County, Delaware County, Lucas County and Mahoning County; they run simulcast systems although they're not part of MARCS.
In most areas of the state where stand-alone tower sites are in use, the following will work just fine:
GRE: PSR-500, PSR-600
Radio Shack: Pro-106, Pro-197, Pro-668
Uniden: BC296D, BC796D, BCD396 (any version), BCD996 (any version), BCD436HP, BCD536HP, HomePatrol, HomePatrol II
Whistler: WS1040, WS1065, WS1080, WS1088, WS1095, WS1098, TRX1, TRX2
However, in areas where simulcast sites are in use (noted in the database) the Uniden SDS-xxx scanners or the Unication G4 or G5 pagers are almost necessary. They cost more, but the other scanners do not perform well with simulcast unless you're really, really lucky.
I live just outside Franklin County and use an SDS-200 for monitoring Franklin County, but a Pro-197 and BCD996XT work just fine for the adjacent counties.
If you're in Wheelersburg you should be fine with one of the less expensive models; all the sites down there are stand-alone.
In Cincinnati, Ohio I use a
Unication g-4
Yes I'm very happy in fact I had a sds-100 uniden at same time and after about a month I sold the sds-100 and kept the unication g-4Are you happy with this performance as a scanner on MARCS?
I have a G5 on Marcs and have run it through the entire state and it performs flawlessly
You can or you can use wildcards, but on P25 you kind of have to get a feel of who affiliates with what site, if you are listening to a Cincinnati talk group usually those are on the Cincinnati and Hamilton Sites and you lock on to say the Warren County site you will miss transmissions, you cant select a site manually, it will pick up whatever you have programmed automatically, and it won't scan a site like a normal scannerDoes it let you program every site?
