AC2OY
Here are a couple of suggestions to improve your ground system. Ground rods should be no closer than twice their length. Putting them closer does not increase your ground. It looks like your master ground rod is where your surge arrestor is located. Your electrical ground should also connect to the same point along with your equipment grounds (is that the ground wire going into the house). The National Electrical Code requires that ALL ground rods be connected together to the same point including the electrical ground. It looks like the surge arrestor could use some more weather proofing. What you have is pretty good and probably better than most ground systems
BB
Thank you I can't take credit a member of my club who is a engineer did the grounding,soldering, and I did the drilling and the hammering. We still have one more antenna to install but for now I'm having a lot of fun on HF!! I haven't tried that antenna on 6 meters yet but I think I read that somebody tuned it to 6 could be wrong.
