Hey Dylan
I read this as requesting duplex'r information, but not giving anything as to what you want to do with it. Is it for a repeater?.... separating two antennas?....etc. The others responding have given you some good ideas, but these are along the lines of your building a repeater, which may not be the case.
Personally I like taking the experimental routes to these issues... I am a 'coffee can' -filter type, and since you are new to all this, it represents a good opportunity to learn. There are plenty of resources on how to construct them- the older ARRL Handbooks, for example, have plenty of good, simple designs for V/UHF notch and band pass filters-- constructed from aluminum minibox's, or my favorite, large diameter copper pipe. Using a handful of air variable capacitors and some N, or BNC connectors you can construct a very respectable unit....Or you may consider helical wound filters-- And while it is nice to have the lab equipment to tune them, you can do a fairly decent job my using your ear and S-meter- just run very low power when you start out, and lower your expectations as to insertion losses and such.
While is nice to be able to buy one new, ready, out-of-the box- what is in that box remains a mystery, and if something goes wrong - then you need someone else to handle it.
Sorry--was I lecturing??...
I didn't mean to. If there is more information it will be easier to help you.
Smiles
................................................CF
