Where to install TYT TH9800 in Jeep Cherokee (KK)?
TA2BQS
Çankaya/ANKARA/TURKIYE
I bought a TYT TH 9800 radio last week. Where and how can I install this device in my Jeep Cherokee (KK) in the easiest and most effective way? Thank you in advance for your ideas.
Offers containing pictures or sketches are preferred.
ladn
Fortunately, the radio is capable of "spit mount" (the radio box can be mounted in a different location than the control head/microphone). That gives you a lot of options. I'd recommend adding an external speaker as well.
We've had a good number of posts about radio mounting-it's more involved than simply where to put the radio:
  • Get radio power directly from the battery, using an appropriate wire gauge for the current draw
  • Antenna selection and placement are important (avoid antennas from companies whose name you can't pronounce)
  • Avoid placing the control head on top of the dash
And while not mounting related, get the RT Systems programming software
TA2BQS
Thank you for your answer. I found youtube videos.
1. I will get radio power directly from the battery
2. I've bought Diamond CR9800 quad band antenna
3. I got original TH9800 programme
ladn
Good plans. Remember proper fusing and wire routing.
The OEM TYT software is functional, but you might find the RT Systems software more user friendly.
The 9800 is a quad band radio, but it's FM only. Is FM widely used on the 10m band in Turkey? Here in the USA, the 10m band is primarily USB and FM is relegated to a few channels for repeaters and simplex in the upper end of the band.
TA2BQS
First of all, thank you for your answer.
I use TYT original software and CHIRP software together.
As for the 10 M Band, there are both FM and USB devices in Turkey. However, the 10M band is not used as much as it used to be.
