Give us more info.
What type of antenna do you have ?
Have you programmed the trunked freqs as prescribed in the RR Database ?
Can you detect a signal on the control channel ? If not, then the answer is no. You're to far away.
Macon/Bibb is a mixed mode 3600 baud system if not 100% digital by now...The Pro-95 will not decode the digital xmits. If analog is still in use, you should be able to receive some stuff provided you are getting the Ct channel.
