Which Cable...
Grog
Banned
West of Charlotte NC
It depends, what are you going to use it for?
1" hardline is overkill for 31mhz, but really sweet for 1.2ghz
N
N_Jay
Guest
astrodanco said:
Whackerboy said:
What is the best coax cable to use for a length of 25 to 50 feet??
I'd use LMR-400, just because I can. If I was a lazy cheapscape, I'd use RG-6QS (quad shield).
One thing to note, the sheilding has very little effect on a receive system like a scanner.
What is important is the loss of the cable.
Loss can be related to the overall quallity, and QS cable might be of higher quallity than the average hardware/electronics store RG-6.
It's hard to say, but in general, I would go with a name brand RG-6 over a cheap RG-6 QS.
Keep your loss under 3dB and you will do fine. For short runs any cable will work. What is short? Short is under 3 dB at your highest desired frequency.
Google 'Coax loss dB' and do some investigation.
Either that or shoot off some emails and get some cable catalogs for your bookshelf! (They have great loss charts in them)
scanjunkie
Montgomery County, PA
Great info all...thank you very much. I pretty good with the scanners themselves, but as far as the technical end of antennas and cables...I just don't know!!
Thanks!!
kb2vxa
Banned
Point Pleasant Beach, N.J.
"Great info all...thank you very much. I pretty good with the scanners themselves, but as far as the technical end of antennas and cables...I just don't know!!"
You're learning. Oh, when you learn what "whackerboy" means you'll change your name.
