RG-213 is the best of the coax mentioned for a 50ft run and by a lot depending on frequency range. For short jumpers under a few feet I would use RG-58 over RG-8X.Which is the better coax for 50 feet and less rg8x, rg58, rg213, I mainly listen to frequencies in the 150's
Is the rg213 thicker than rg11 or rg8x, I forgot to mention lmr 400 on which is betterRG-213 is the best of the coax mentioned for a 50ft run and by a lot depending on frequency range. For short jumpers under a few feet I would use RG-58 over RG-8X.
Do you go by the lower db are more kwHere are a couple of handy charts to reference. Both have data that can be used to make a choice.
DX Engineering Coax Specifications
Universal Radio Coax Performance
Depends on if you're receiving or transmitting. If you notice, the longer runs at higher frequencies attenuate (i.e degrade more) and take less power.Do you go by the lower db are more kw
Which coax would you prefer that has less loss for receiving 150 mhz rangeDepends on if you're receiving or transmitting. If you notice, the longer runs at higher frequencies attenuate (i.e degrade more) and take less power.
For receiving only, you want less attenuation (read less db/100 ft of coax).
Lower dB (assuming that all are listed against the same reference. For example, dbi shows larger numbers than dbd for the same level. Typically coax loss charts all use the same reference so this isn't a problem. When comparing antennas, you'll typically see the gain listed in either db, dbi, and dbd. The db number doesn't provide a reference so you should assume dbi just to be safe. The dbi number is referenced against a theoretical antenna that doesn't exist in reality but used by engineers as a standard reference. The dbd number is referenced against a standard dipole antenna that can actually be built and used. The dbd number is 2.15 units smaller than the dbi number so it may appear to have more gain when it actually doesn't.Do you go by the lower db are more kw
RG8, RG213, RG11, and LMR400 are generally about 1/2" in diameter. RG8x is smaller at about 1/4" in diameter. The specs on all of them are different (even if they are the same diameter) due to other factors. Use a good coax loss chart or calculator when selecting your coax. Be aware that there are several different types of most of these RG type coaxes and you can't assume that one brand's RG8 is the same as another brand's RG8. Also note that even within the same brand, they may have different types of RG8 with different loss or other specs. (Note: I'm using RG8 as an example here and the same goes for other types. Also note that RG8 is vastly different than RG8x so treat them as totally different types of coax.)Is the rg213 thicker than rg11 or rg8x, I forgot to mention lmr 400 on which is better
For 50 feet, I doubt you'll see much of a a difference with any of the coax you mentioned. Typically what I do is use a low-loss cable through the walls and up to a wall jack, like LMR400 or LMR600. From there, I use a smaller, more flexible, patch cable like RG-8 to go from the wall to the radio.Which coax would you prefer that has less loss for receiving 150 mhz range
That would depend on the length of your run and your installation. For the typical hobbyist with a run between 50 and 100 feet long, a quality brand of LMR-400 would be a good option. This is a fairly cost-effective type of coax for this use and should serve you well. Avoid the off brands though since you may get something that appears to be LMR-400 but is of very poor quality and generally a waste of money. Times Microwave Corporation is one of the go-to brands. I'd avoid most of those on eBay and if the price is much lower than others, you're probably getting some low quality knock off stuff of questionable quality.Which coax would you prefer that has less loss for receiving 150 mhz range
I have used radioshack 50 feet rg58 in the past it did pretty good, are they any need to get an more expensive coax to tell the differenceFor 50 feet, I doubt you'll see much of a a difference with any of the coax you mentioned. Typically what I do is use a low-loss cable through the walls and up to a wall jack, like LMR400 or LMR600. From there, I use a smaller, more flexible, patch cable like RG-8 to go from the wall to the radio.
If that's what you're currently using and don't notice any issues, I wouldn't worry about it.I have used radioshack 50 feet rg58 in the past it did pretty good, are they any need to get an more expensive coax to tell the difference
That's probably RG-6. It'll work fine, but I'm not sure I would call it low loss. There are better options, especially for long runs and/or if you have weak signals.Let me offer some real heretic advice, 75 Ohm satellite coax! Very low loss, low cost and don't worry about the "impedance mismatch", god knows what your radio's input impedance is anyway. Need to find some F connector "adaptors"on ebay You may laugh....
, think what you want! I mean LMR400 is nice, fat and expensive but you don't transmit. I bet you won't notice the difference - other than what's left in your wallet!
If I ever needed to replace the rg58 what should I go withIf that's what you're currently using and don't notice any issues, I wouldn't worr
RG-8If I ever needed to replace the rg58 what should I go with
Here we go....But whatever you do, make sure you rotate it.
