BC125AT: Which "set up" file do I click on??
Blackink
Central Vermont
I extracted the contents of the zipped file for the BC125AT software from the Uniden Web site, but I now see 2 files labeled setup.
One has "setup", then "setup" right below that.
The other has "setup", then "Windows Installer Package" right below that.
Which one do I click on to install the software? Neither one has the "exe" on the end, even when I look at the Properties of each file.
I followed the instructions:
Right click and save BC125AT_SS_V1_01_00.zip to your local PC.
Unzip the files to a temporary directory.
Double click the file "setup.exe" to install the software.
I don't own a BC125AT but I'm curious as to how the software works as I might purchase one in the future.
Thanks.....
fxdscon
¯\_(ツ)_/¯
Thanks.....
When I unzip that download, I get one setup.exe file, and one setup.msi file.
In your folder options - view settings - you probably have the "Hide extensions for known file types" option checked, that's why you can't see them.
