Whistler 1040
kamccullers
My dept just went to a 700 trunked system in Prattville Alabama using the Montgomery Metro CCD as the backbone. My Batt chief's parents bought a whistler scanner to listen to us. I was going to program it for them. Where is the software on this site and how do you program it?
Andrew
Andrew
tvengr
Well Known Member
Baltimore County, MD
The T in the Mode column for Prattville Dispatch means it is P25 Phase 2 which the WS1040 cannot decode. The Prattville Ops talkgroups are fully encrypted which no scanner can receive. The WS1040 can decode Autauga VFD.Dispatch which is P25 Phase 1 (D in Mode column).
7152cbTPrattvll FD DispPrattville Fire DispatchFire Dispatch
7162ccTEPrattvll FD 716Prattville Fire OperationsFire-Tac
7192cfTEPrattvll FD 719Prattville Fire OperationsFire-Tac
7362e0DAutauga VFDVolunteer Fire DepartmentFire Dispatch
kamccullers
Thank you. They bought it without research.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
TAbirdman
MO
At the minimum a P25 Phase-II capable scanner will be needed to bring this system in. Simulcast distortion doesn't appear to be a factor on the Prattville site so any scanner listed below should do
Scanner Support for TDMA
The following scanners can decode P25 Phase I, Phase II, and Motorola X2-TDMA systems.
I believe the Pro-18 is Phase I only. It can't decode Phase II unless it has the DMR upgrade from Whistler.
tvengr
Well Known Member
arc500 is free and great for programing in freq and trunked will need the cable to upload to scanner
That is not correct! ARC500 is paid software as well as PSREdit500. Both have a free trial period to determine which one you like better. There is no free programming software for the WS1040.
