- Joined
- Jun 2, 2024
- Messages
- 3
Hi All,
I've been trying for a few weeks and coming up sort with trying to program my Whistler 1065.
Background-
I inherited this scanner with pre-programmed frequences from a deceased relative that lived in my area. I did not receive the USB cable.
I've purchased two different cables for the scanner:
This cable on amazon
This cable (or something like it) on eBay
I have not been able to find an in-stock version of the official cable.
I do not use the mono adapter to connect.
Of note:
Both cables seem to work- I can trigger the software download on the scanner and manipulate the scanner in ARC500's virtual control, so I know the cable is working, so it doesn't seem to be a driver nor cable issue.
Software:
I've tried everything I've heard mentioned here, but the one I try most is Arc500. I currently have a demo version which is supposed to have the same support as full. I'm not going to be purchasing the software if I can't get it to work.
I've made sure I have the latest release of Arc500, I've installed the Default drivers with ARC, as well as the drivers that came with the cable.
Running the software in windows compatibility mode for win7 doesn't seem to matter. My computer runs on win10.
Communications Port:
Comm4 generally speaking. It's been assigned and working properly, I'm fluent in figuring this out, I have many devices that need custom comm port configuration, from WSJT-X to My telescope. I'm not really sure what baud rate the whistler defaults to, nor any of the other custom options, so I've left those to default.
The error:
The default file folder \My Scanner Data Files\ARC500 ends up with the below commerror.txt file:
06-07-2024 com error0 where 06-07-2024 is (obviously)the date despite multiple runs and boots of the program, this is the only line.
The experience:
It doesn't seem to matter if I start the software with the cable plugged in or not, nor with the radio on or off, the user experience is the same:
I go to Scanner -> Download from scanner.
Select usb/comm4 (interestingly I display all usb/comm#'s from 1-99) then start download.
The radio will switch to filesys->clone, run to 100%, then reboot pretty quickly.
Nothing happens software side, the progress bar doesn't move, the green start download box doesn't unclick itself.
The object information screen doesn't update with numbers, all remain at 0.
Clicking into conventional/talk groups/etc. all gives no data.
The backup/restore utility acts the same, gives a chance to name the backup file, but no file is generated.
Virtual control works fine, I can change the LCD brightness, run through the menus, toggle scanning, etc.
I haven't tried uploading anything as I've heard uploads overwrite existing data. Keeping the data currently in the radio is important to me.
Anyone see anything I'm missing? I'm getting terribly frustrated.
Background-
Programming Cable for Radioshack GRE Whistler Scanner | eBay
Work with model: RadioShack models: PRO-106 PRO-135 PRO-136 PRO-137 PRO-163 PRO-164 PRO-197 PRO-404 PRO-405 PRO-426 PRO-427 PRO-428 PRO-444 PRO-496 PRO-501 PRO-515 PRO-522 PRO-523 PRO-524 PRO-525 PRO-526 PRO-527 PRO-533 PRO-649 PRO-650 PRO-651 PRO-652 PRO-2017 PRO-2018 PRO-2054 PRO-2055 etc.
www.ebay.com
Of note:
Software:
The error:
The experience:
