Whistling Background Noise
BeaconKid
Background noise like wind whistling, hear it on my feed TOWN OF PLYMOUTH FIRE. Help to eliminate it?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Welcome to the RR forums. Specific info goes a long way to help us help you. Please provide:
  • Make & model scanner or SDR(s) you are using to stream
  • Software app(s) you are using to stream
  • How are you feeding audio if using a scanner, via sound card, wifi or other means?
  • Link to feed in question so we can get ears on it and hear the issue for ourselves
hiegtx
Dallas, TX
Your profile is not tagged as being a 'Feed Provider'.
Are you actually referring to this feed, provider by someone else?
Have you used the "Report a Problem" link on the feed's page?
If not this feed, as Whiskey3 noted, provide a link to the actual feed you are referring to.
Whiskey3JMC
I skimmed through a few archived files on that feed above, didn't hear "whistling" like the OP described. Nothing but typical background hum experienced on analog repeaters, really no way to eliminate that...
hiegtx
Dallas, TX
Sounds like the issue may be interference at the OP's location or in whatever he is using to listen, not an issue with the feed itself.
