TRX-1: WHRISTLER TRX-1
buddrousa
The Whistler TRX-1 Code-500 error means there's a problem with the microSD card, usually fixed by reformatting it using the TRX-1's EZ-Scan software to prepare the memory and copy configurations; if that fails, try a new card, as the original might be corrupted from sudden power loss.
jeffkett
Cape Cod , MASS
Recently had same error code on my TRX-2. Would try to load up to 15 %, then freeze up with code. Picked up a new card, formatted , and reloaded last version I had programmed. All was good. I did suffer a power outage with bad flickering for about 45 seconds - I believe that was the culprit.
Jeff
