Henry, the SMA connection is designed to be a cheap high efficiency connection supposedly for "internal" use, i.e. between two components in one housing. Assemble once and walk away, never used again unless repairs are being made.
So for handhelds, which only need "final assembly" of the antenna once when it is put in use, or for WiFi routers, again needing assembly only once when they are put in use, it is perfectly sensible.
If you plan to abuse it by swapping out antennas the threads will cross and you will have problems. Most users can't get that through their heads, this is not how the SMA is supposed to be used. You might as well complain that the h/t does not work very long when you use it as a hammer. Well, duh, it ain't supposed to be used as a hammer!
You can spend about $10 to but a simple SMA-to-BNC adapter that screws firmly onto the SMA of your radio. Slip a small o-ring under it is there's any gap that might let water in. Use a tad of thread lock if you have a problem with it coming loose. (Shouldn't need it.)
Then just buy BNC antenna's and cables, and one little twist gets them on and off, many many times. Which is what the BNC is designed for. That's the right way to do things.
Or, you buy an SMA (or BNC) pigtail, a foot of thin coax that has a PL-259 or SO-239 on the other end. And you use the pigtail when you want to hook up to a standard antenna cable with a big ugly connector on it. Stain relieve that pigtail's flimsy cable by looping it around the battery clip of your h/t, or some other way, because that thin cable also is not meant to be very robust, it is meant to make sure that a bigger cable doesn't stress and damage the SMA stub installed in the h/t.
