Anytone Why doesn't Anytone D878VII Plus decode Commercial DMR Audio?
crowleyd102
St. Louis
I have both an Anytone D878VII Plus and a COTRE CO01D. I opened up the Anytone Radio using AT_options, and built a code plug including a local commercial DMR repeater system at 464.6500 MHz. I have the same repeater in the COTRE radio which decodes the commercial DMR audio well. The Anytone receives the RF signal from this repeater but doesn't decode the audio.
I've run into this issue before with another amateur DMR transceiver vs. a Uniden scanner.
Any ideas,
Thanks,
Dave N0HMI
crowleyd102
St. Louis
Does anyone know what the AT-D878VII Plus band plans other than 7 or 14 do.
I'd like a band plan, if possible, that expands the UHF xmt limit above the US ham band and does not eliminate the scan option from the radio's main menu.
Thanks again
Dave
alcahuete
Antelope Acres, California
If I recall:
0136-174 / 400-480Commercial Europe Mode
1136-174 / 400-480Commercial US Mode
3144-146 / 430-440Amateur Europe Mode
7144-148 / 420-450Amateur US Mode
8136-174 / 400-470Commercial Mode
10144-148 / 430-450Amateur Australia/Canada Mode
13136-174 / 403-470Commercial Mode
16144-147 / 430-440Amateur Thailand Mode
17136-174 / 430-440Commercial Thailand Mode
