Wifi Connecting Error
AJ1L
Rockland, MA
All of a sudden my BCD536HP doesn't want to connect to my wifi network. It's been working fine for a long time, but all of a sudden today, I try connecting, and get "Connecting error." No parameters have changed on my wifi network such as the password or anything.
Has my wifi dongle failed?
mule1075
Washington Pennsylvania
Did you try resetting to factory and trying to connect?
AJ1L
Rockland, MA
Another thing I just tried is temporially turning off the security on my network.. that didn't work either
mule1075
Got me only thing else I can think to try is unplug the dongle and shut down the radio for a few minutes. And then try the previous steps other than that is all I can think of.
AJ1L
Rockland, MA
I had tried those steps before as well... Now I just went and re-enabled WPA2 security on my router, tried connecting again and it worked! We'll see if it lasts...
Ubbe
Stockholm, Sweden
My dongle needs to be removed and inserted again to the 536 when "no connection" happens. The same has to be done when the mobile app doesn't connect but the 536 show that the ip is still the same and it has a connection. Must be a TCP or UDP port that dies and cannot be revived and needs a new port number.
/Ubbe
AJ1L
Rockland, MA
The connection failed again sometime during the day today...
I'd tried removing the dongle, powering down, etc before trying the steps that I did last night. Going to mess around with it again tonight when I get home.
AJ1L
Rockland, MA
My router is an Asus RT-AC3100. I'm not having any luck getting the scanner to reconnect tonight at all no matter what I try.
bob550
Albany County, NY
Have you tried changing the IP address, and then configuring the new IP as a static address in your router? Have you added/deleted anything from your home network recently?
jonwienke
More Info Coming Soon!
VA
You have to reserve an IP address for the scanner in your router, or the connection will be interrupted every time the IP address lease expires (usually every 24 hours).
belvdr
Normally, internal IPs rarely change unless the device is offline for a period of time. Why does Uniden do that I wonder?
jonwienke
VA
The connection gets interrupted, regardless of whether the IP address actually changes, if the IP address is not reserved.
belvdr
That makes no sense. You're saying without a reservation and if the IP stays the same, the connection is interrupted.
How does making a DHCP reservation change that? If so, this is a unique Uniden thing.
AJ1L
Rockland, MA
Thanks for the tip. I just set it as a reserved DHCP address, different from that address than it had been, and it immediately started working. Hope this lasts!
belvdr
That makes even less sense, because you forced it to change the IP.
I hope that works for you, because, from a technical standpoint, it has me baffled.
jonwienke
VA
Something in the DHCP lease renegotiation process borks the connection. Setting a reserved IP eliminates the daily lease renegotiation, and guarantees a consistent IP address (mandatory if you want to use logging or remote access without daily reconnect/reboot).
