Wiki References
Check another wiki page that has references or links and use that as a template. Here is a sample from the NC Viper RID page...
==Related Links/Maps==
'''Direct links to Various District and Regional Maps for State Agencies''':<br/>
*[NCSBI - District Offices NCSBI District Offices]
*[NC DPS: Troop Offices NCSHP Districts and Troops]
*[https://connect.ncdot.gov/projects/planning/STIPDocuments1/Division Boundaries Map.pdf NCDOT Districts]
*[NC DPS: Map NC-RRT Hazmat Districts]
*[https://files.nc.gov/ncdps/documents/files/Map.pdf NCDPS/PO Districts]
*[NC DPS: About ALE ALE District map (at bottom of the page)]
*[North Carolina Forest Service NC Forest Service Regions and Districts]
*[https://www.ncwildlife.org/Portals/0/About/documents/NCWRC_District_Map.pdf NC Wildlife Resources Commission Districts]
*[https://www2.ncdhhs.gov/dhsr/ems/pdf/regions2.pdf NC Office of Emergency Medical Services Regions]
*[U.S. Marshals Service, North Carolina Federal Agencies in NC use same districts as USMS]
Return to DB page: {{DB|s|7118|North Carolina VIPER (P25)}}<br/>
Return to Wiki page: [[North Carolina VIPER (P25)]]<br/>
firebal
Baltimore, MD
Thank you and if I created an redundant page like I did (sorry) who deletes it?
u2brent
OAMPT
KRWDPAXKRS1
You should move the data on the page you created
to this page..
Then delete the page you created. IDK Just a suggestion.
The page you created is an ophan that is not linked to any other page. (Of course this can be corrected, but it appears there is another page already created for the same purpose. (I'd edit/add to that page instead)
u2brent
OAMPT
KRWDPAXKRS1
I believe the wiki guru's will delete the page eventually, I'd just blank that page and make sure any linked pages (If any) are also corrected to remove any links to that page..
