Wildwood NJ
maintmanager
cape may
Good morning just trying to find out I believe wildwood police changed their frequency I know they didn’t switch to county so if anyone can find out I would appreciate it. It was definitely changed within the last 2 days
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Please confirm you're no longer hearing them on 154.965 (411 DPL), it always helps to include the frequency(ies) you have record of & what make & model scanner(s) you are using. If this is the case it's possible they could have followed suite with surrounding communities and migrated to NJICS so if you or someone else is in the area I'd recommend searching the Cape May County Simulcast for unknown TGIDs to see if one contains similar traffic to what was heard on the analog VHF frequency (assuming no encryption of course)
maintmanager
cape may
Ok thanks yes that is/was the frequency but seems it has changed within the last day or two
GTR8000
NY/NJ Database Guy
BEE00
Ok so it seems they did switch over to simulcast and site id is 5273 thanks again
5273 would be the Talkgroup ID, not a Site ID. If you've confirmed that Talkgroup 5273 is Wildwood PD, please submit that to the NJICS system in the database so it can be added. Thanks.
