Will this work?
wtp
Port Charlotte FL
for reception only, there are no rules.
but with the 'ends' connected, you only get half the resistance.
could you tell us what radio this is for ?
It's for scanning, really any scanner I need it for. I tried it with mixed results. I asked the forums to see if this is the electrically correct method of wiring this.
wtp
Port Charlotte FL
it took a minute to figure out what you had attached the wires to.
a rheostat/volume control is a resistor connected at the 'ends' and arm that swipes from end to end, that is the middle connection.
wtp
Port Charlotte FL
i hope i can get this right.
antenna cable center to one of the outside legs.
radio cable center to the center leg.
grounds on both cables tied together.
........L
so the ends are the whole resistor.
the center swipes from side to side. (the L) (sorry about the ...but the L shifts to the left if i omit them)
so at one point it is no resistance (0 ohms)
and at the other it is maximum resistance.
L
Ideally yes
wtp
Port Charlotte FL
but in the pic you have electrically connected the ends together.
(resistance is futile)
1659485220098.png so says the borg...
now for reality.
with it connected that way the best you can get is half the resistance.
so if it is a 500,000 ohm you can only get 250,000 and then it goes back towards zero
But wait, if the wire is only connecting the ground of one coax to the other, and no signal is coming across would it really impact resistance between the wiper and first pin?
Ubbe
Stockholm, Sweden
Will it work?
It looks like a reostat, a potentiometer for high power, maybe for a speaker, that are done by winding a coil over a ceramic body and the wiper goes over the top of the windings. That inductance are radio frequency dependent. To be useful the resistance for the potentiometer would have to be something like a 500 ohm type or lower down to 50 ohm.
It needs to be a shielded box with proper connectors on the coax. It will now receive all the interferences you have in the room.
/Ubbe
